ssi112's avatar
ssi112
Can no longer connect to 5G network after firmware upgrade
I upgraded my Nighthawk X6 AC3200 to the latest firmware version: V1.0.4.28_10.1.54
Now I can no longer connect to my 5GEXT network.
My laptop doesn't even show the network any longer.
On my smartphone it says "Failed to obtain IP Address"
I Enabled Smart Connect then restarted the modem, router, and extender.
The result is the same.
How can this be fixed?
Thank yo
  • Have you tried to disable smart connect and rename the 5ghz network and see if the network shows back up?
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
    • ssi112's avatar
      ssi112
      It took a couple of reboots of the extender, but renaming the networks appears to have worked.
      Thanks
