htuggle
Dec 12, 2013Aspirant
Can not connect WN2500RP to AT&T router
I have tried the installation guide options #1 and #2. #1 the extender never picks up the signal from the router even when it placed directly by the router. #2 my network map does not show the WN2500R...
htuggle
I have reset the extender twice and yes two laptops and two smartphones connect to the AT&T router.
I am at a loss as to what I should do. Before I went with AT&T Uverse I had installed a couple of routers, one of them a Netgear and was able to get them up and going.
I think I need to return this extender.
Thanks,
Thanks,
