bhaynes
Aug 07, 2023Aspirant
Can not get http://mywifiext to come up Ac1200 Wifi Range Extender
Hi, I have attempted for WPS and the Installation Assistant for my extender. I have went through all the steps MULTIPLE times. The extender is connected to my router correctly and shows i...
bhaynes
Aug 13, 2023Aspirant
I want to be able to log into the interface to change settings to the extender.
I tried using the extender's ip address. I get "This Site can't be reached"
bhaynes
Aug 14, 2023Aspirant
This site can’t be reached
(my ip address) took too long to respond.
Try:
- Checking the connection
- Checking the proxy and the firewall
- Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
Check your internet connection.
Check any cables and reboot any routers, modems, or other network devices you may be using.
Allow Opera to access the network in your firewall or antivirus settings.
If it is already listed as a program allowed to access the network, try removing it from the list and adding it again.
If you use a proxy server…
Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don't believe you should be using a proxy server: Go to the Main menu > Settings > Change Proxy Settings… > LAN Settings and deselect "Use a proxy server for your LAN".
