bhaynes
Aug 07, 2023Aspirant
Can not get http://mywifiext to come up Ac1200 Wifi Range Extender
Hi, I have attempted for WPS and the Installation Assistant for my extender. I have went through all the steps MULTIPLE times. The extender is connected to my router correctly and shows i...
bhaynes
Aug 14, 2023Aspirant
The network shows in the list for available networks( and I am able to connect to it). However I can not log in to mywifiext to change settings on my extender or to sign up for a new acct, I can not use the IP address either. Now sure what I am doing wrong. I have tried using my desktop and my phone. Nothing is able to pull up anything. I assume there has to be an issue with my router or something?
schumaku
Aug 14, 2023Guru - Experienced User
bhaynes wrote:
The network shows in the list for available networks( and I am able to connect to it). However I can not log in to mywifiext to change settings on my extender...
Lets' try to bring some transparency what is "the network" (limited to where the fancy name resolution is active)
The extender creates two new extender WiFi networks. The extender’s new WiFi network names are based on your existing WiFi network name, with _2GEXT and _5GEXT at the ends of the names.
For example:
• Existing WiFi network name. MyNetworkName
• New extender network names. MyNetworkName_2GEXT and MyNetworkName_5GEXT
Use the same WiFi password that you use for your WiFi router.
Only when connected to the MyNetworkName_2GEXT and MyNetworkName_5GEXT networks, this name resolution can be workable - not on the MyNetworkName network.
Note: I said can because some more fancy modern OS might use secured DNS (encrypted) for privacy. In these situations, the mywifiext or mywifiext[.com] or mywifiext[.net] and so on will resolve to the public IP address pointing to the landing page.
bhaynes wrote:
... to sign up for a new acct... .
What new account again, please?
You can find the extender LAN IP on your router DHCP resp. "connected devices" list, when looking up the extender MAC address. Whatever default extender LAN IP you might have in mind are not active once the router DHCP has assigned an IP address
- bhaynesAug 15, 2023AspirantI was referring to registering my extender. Don't you have to create an acct to do that for warranty purposes?
- schumakuAug 15, 2023Guru - Experienced User
Keep things easy, for the product, head to https://my.netgear.com/ -> Product Registration 8-)
The point is that design some heroes had added some e-mail-named user accounts, here they request a lot of data - not adding any real purpose.
- bhaynesAug 15, 2023AspirantThank you 🙂 😊
- bhaynesAug 15, 2023AspirantCan you explain how to connect my extender in layman's terms?
