mjshuster1's avatar
mjshuster1
Can the WiFi Extender's Ethernet port be configured as an input instead of output?
I understand that, as shipped, the Ethernet port on the WiFi Extender is essentially just an output in case you have any devices nearby that need to be plugged in.  But I was wondering if I could cha...
  • netwrks's avatar
    Feb 05, 2016
    An extender uses wifi only. What you are describing is an Access Point, which some extender's do support. Check out the documentation for your extender, to see if supports AP mode.
    Use this link: http://support.netgear.com/for_home/default.aspx - click on network Icon to drill down..
