bcadou
Jul 12, 2012Follower
Can WN2500RP extend a 2.4ghz into a dual band one
Hi I have a 2.4ghz network that I want to extend with a WN2500RP (i havent bought it yet, but am about to). Can I extend it, into a new 2.4/5ghz simultaneous network? If not, can I at least exte...
ussperrydd844
Aug 04, 2012Aspirant
This is a very difficult range extender to get up and going. There is virtually no paper work or instructions to give you any idea about what is going on with it. You are pretty much flying by the seat of your pants with it. You will find that it shows connected but will not not know what it is really doing or if it is actually extending. There are no final results illustrations to guide you.
Mine, which I am about to return, indicates it is connected and not connected at the same time.
There has to be a better choice
