DaveFrei
Sep 22, 2015Aspirant
Cannot configure N300 Extender
I am trying to set up my extender. I go to www.mywifiext.net and am able to find my network and set it up. I am able to put in security etc, It then says to wait while the extender finishes setup. Bu...
DaveFrei
Sep 23, 2015Aspirant
I have the WN2000RPT. I am trying to extend a network with an Apple Airport Express router. When trying to set up network/extender, I was about 10-12 feet from router. Through genie, I was able to find network and configure, but when it would try to finalize, genie would just start over at finding existing networks.
nhann
Sep 23, 2015NETGEAR Employee Retired
Please try connecting the WN2000RPT and Airport Express via WPS.
For WPS on the Airport:
Open the AirPort Utility, select your router and click "Manual Setup."
Next open the "Base Station" menu, located on the display's top menu bar, select "Add Wireless Clients..." and proceed.
You can also connect ethernet from your computer to WN2000RPT and proceed with setup. Once the connection is established. Open an internet browser and go to mywifiext.net
