LarryStein's avatar
LarryStein
Cannot Connect via Wifi to N300 Router
I had done setup 3 months ago and the device was working well. Then last week, I was not able to connect from my MacBook to the range extender.  I turned it off/on - no change. I unplugged -- no change.  I then did a factor reset - which took 2-3 times and finally did so successfully - then was still unable to connect to the range extender at the end of the setup.  Now have spent 2-3 hours on this - and no change.  My iPhone has the same issue.
I then tried deleting the network from my MacBook and reconnecting -- no go.
Suggestions?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello LarryStein
    Do you have your extenders SSID set with the same name as the main router? if so you may need to have separate SSID.
    DarrenM
    • LarryStein's avatar
      LarryStein
      It is a different SSID.  This was the case during installation -- and is still the case.
      • DarrenM's avatar
        DarrenM
        Have you updated the extender to the latest firmware?
        DarrenM
