Wallace19xx
Jul 27, 2015Follower
Cannot connect WN3000RPv3 to Netgear AC1750 R6300v2 router
I never got the Router Link LED to show any color after I successfully setup the new _EXT network. Do I need to worry about Microsoft's firewall manager?
- Kinson2339Aspirant
I keep getting error messages when trying to conect my WN3000RPv3 to the standard issued Sky router. I have went to the extent of changing the router (new). I have went back to the factory setting Netgear extender and started from the begining, disabled firewall etc but still get error messages i.e 404 file directory can not be found. i have been working at it for approx' 3 days off and on. if it does not start working ----GOES to rubbish BIN
- nhannNETGEAR Employee Retired
Hi Wallace19xx,
When finishing the new setup for the _EXT network, did you reach a success page? http://www.netgear.com/success/wn3000rpv3.aspx?sn=3Y11485P00093
Is your R6300v2 running the latest firmware? http://support.netgear.com/product/R6300v2
Please also try a factory reset for the WN3000RPv3.
----Hi Kinson2339,
Can you please provide more details on the error that you are receiving? Is this error showing when you access the webpage to setup the WN3000RPv3?
I look forward to hearing from you.Regards,
NhanN
