rmarcus88
Jan 05, 2018Aspirant
Cannot finish Genie setup (WN2500RP)
Hello, I've been using my Netgear WN2500RP in a few different apartments very successfully for a few years now. However, in my most recent move when I try to set it up through the Netgear Geanie ...
DarrenM
Jan 10, 2018Sr. NETGEAR Moderator
are you factory resetting the extender before trying to set it up again?
DarrenM
- rmarcus88Jan 10, 2018Aspirant
Initially no, but yes, I have done a factory reset with and no different result.
- DarrenMJan 17, 2018Sr. NETGEAR Moderator
I suggest contacting support could be a issue with the extender.
http://www.netgear.com/support/contact.aspx
DarrenM
