rmarcus88
Jan 05, 2018Aspirant
Cannot finish Genie setup (WN2500RP)
Hello, I've been using my Netgear WN2500RP in a few different apartments very successfully for a few years now. However, in my most recent move when I try to set it up through the Netgear Geanie ...
DarrenM
Jan 10, 2018Sr. NETGEAR Moderator
are you factory resetting the extender before trying to set it up again?
DarrenM
rmarcus88
Jan 10, 2018Aspirant
Initially no, but yes, I have done a factory reset with and no different result.
- DarrenMJan 17, 2018Sr. NETGEAR Moderator
I suggest contacting support could be a issue with the extender.
http://www.netgear.com/support/contact.aspx
DarrenM
