Sjorrit's avatar
Sjorrit
Tutor
Mar 15, 2022
Cannot login on router through browser
Hi all, I bought a second hand EX8000. I performed a factory reset of the device and then did a setup of the EX8000 using the Nighthawk Android app. So far everything works great but I would like to...
  • plemans's avatar
    Mar 15, 2022
    A reset should clear those out.
    AFter the reset, try setting up using the browser and not the app.
    That should let you start with the default admin/password option.
    And you can customize it afterwards.
