goldstar
Mar 10, 2015Novice
Cannot Open 192.168.l.l
Cannot Open 192.168.I.I
Hello,
I have BSNL boadband, whenever I try to connect 192.168.I.I it shows explorer cant connect. I bridge connection, I want it to be direct.
Thank you :confused::confused:
goldstar wrote: Cannot Open 192.168.I.I
Are you really typing that?
It should be 192.168.1.1.
That's not what you typed. - Sleepy_JoeNoviceMake sure that your computer's IP Address is in that range or else, you won't be able to open it. Try to ping that IP Address too. If you're getting replies, then you should be able to open it.
- routerwiInitiateThe true IP Adress 192.168.1.1, it is not 192.168.l.l (.L.L)
You can access for router admin settings. - michaelkenwardGuru - Experienced User
