jrcruise
Jun 08, 2012Aspirant
Can't access Extender via www.mywifiext.net
I just installed a Netgear WN2500RP range extender, and it seems to be working correctly; however, I am unable to log in to www.mywifiext.net to access the device using a browser. Attempting to access...
- Aug 13, 2012
pawnslinger wrote: It sounds like the subnet mask in the extender is different from that in your computer. That is a classic problem with this class of device. If you think this might be the case, you can establish communications with the device by connecting it by wire to your computer and making sure your computer has no other lan/internet path (connect while both are powered down). Power up the device first, let it settle a couple of minutes, then power on your computer. With no access to your main router, it will use the DHCP in the device to set the subnet mask and get an ip address. You can now use the browser to access the device.
Okay, I'm having the same problem accessing my Extender using www.mywifiext.net which keeps rerouting to the general netgear support site. Your subnet issue makes sense and is no doubt my problem.
Thru repeated full Extender resets and starting all over from the beginning, I am able to enter the www.mywifiext.net configuration menus UNTIL I select a router to connect to. The moment this connection is made, it seems the router's DHCP subnet immediately takes hold and contact with the Extender is dropped, consequently preventing further settings changes and any web access to the Extender again. Very aggravating!
Your alternative hard-wired access method sounds like it could work but I don't have an ethernet cable at hand to try it. And, some devices these days dont even have ethernet ports. I think I should be able to wirelessly access this unique subnet extender any time I want to make and test various settings tweaks. Maybe I can use the "route" command line to create a static connection between www.mywifiext.net and the Extender's internal subnet. Can you tell me what the default Extender subnet is?
Any other suggestions?
DMcintos
Sep 06, 2012Aspirant
I can access my WN2500 extender via the IP address, 192.168.1.2, but neither the .com or .net address. Both are set up to get their IP address from my ISP so I assume they're getting not only an IP address but using the same subnet mask, 255.255.255.0 - am I wrong?
