Pedowski's avatar
Pedowski
Cant connect to extender (AC1900)
It has worked before, but now i cant connect any device to any of the extended-wifies, everything is green. Will only work if i put ethernet cable from router in to it, but i need it for extending my network.
  • StephenB's avatar
    Did you try resetting the extender and setting it up again?
      • StephenB's avatar
        Do you know what firmware you are running?
        Can you connect a laptop to the ethernet port?  If you can, then try browsing to www.mywifiext.net (which is the extender's web page), and see if that shows the extender connected to the router.
