hanneske26's avatar
Apr 27, 2022
Cant find router in Nighthawk app
With the latest app update
i cant connect my mighthawk app with the Extender EX8000
The extender is working but the nighthawk app cannot find the router
i can login with browser in extender and all is working well
but the app cannot connect??
already performed factory reset on the Extender , then new installation but the nighthawk app won't find the extender in installation proces even when connected to netgear_ext wifi
Extender configured with browser and extender is working great again
but not with the nighthawk app
Any suggestions
  • plemans's avatar
    Are you using a iphone?
    If so, make sure to disable icloud relay, random mac, random ip.
    I've seen them cause a slot of issues lately
    • hanneske26's avatar
      hanneske26
      Tutor
      I'm using i iphone
      tried the solution disable iCloud, ip en mac but that doest do the trick
      johan
      • plemans's avatar
        Tried uninstalling the app and reinstalling?
        It works fine through the browser though?
