DickFromWisc
May 09, 2018Aspirant
Can't get WN3000RPv3 to work!
I've tried to get my WN3000RPv3 Range Extenders to work. But so far I can't even get the thing to pair with the my WiFi Network.
Connect with WPS
I plug the Extender into 120VAC in the room ...
DarrenM
May 11, 2018Sr. NETGEAR Moderator
try to use the default Ip address in your web browser by going to 192.168.1.250 and see if that pulls up the extenders login page.
DarrenM
- DickFromWiscMay 15, 2018Aspirant
Thanks for the suggestion. I copied and pasted that IP address into my browser, but I got this response:
Hmmm...can’t reach this page
Try this
- Make sure you’ve got the right web address: http://192.168.1.250
- Search for "http://192.168.1.250" on Bing
- Refresh the page
This website could not be found.
Error Code: INET_E_RESOURCE_NOT_FOUND
- DarrenMMay 18, 2018Sr. NETGEAR Moderator
you may need to log into your router and look at the attached devices and see what IP address the extender is getting and then use that IP to access the extender.
DarrenM
