markstone1121's avatar
Oct 26, 2017
Can't see both extenders on mywifiext
MYWIFIEXT  What to Do When Unable to access mywifiext ? Mywifiext is a local web address for to open the settings of genie setup and some other wizard of Netgear. When user try to access this web a...
  • markstone1121's avatar
    Oct 26, 2017
    Netgear EX6200 – AC1200 WiFi Range Extender
    To know how to install Netgear EX6200 have premium hardware specs, which are far better than what’s found in most Wi-Fi extenders. The Netgear EX6200 has an 800MHz dual-core processor, for starters. In addition to its 700mW high-power amplifiers, the device also has two 5dBi high-gain external antennas
    There are two ways to set up the Netgear EX6200 using WPS or using the extender’s Netgear Genie setup software wizard.
    • Plug your extender near to the Wi-Fi router.
    • Connect one of your device to the EX6200 range extender via wired or wireless connection.
    • Once you’re successfully connected with your range extender, the client link light will be turn to solid green.
    • Enter www.mywifiext.net in your internet web browser search bar.
    • Click NEW EXTENDER SETUP. And Complete the Extender Setup by clicking NEXT.
    • Choose your wifi network and enter your network key or passphrase and click next.
    • Change the SSID and passphrase of your extender or just use the same existing network password and click next to save the settings and click to continue.
    • After saving the setting, connect your device to the mywifiext.net EX6200 SSID before clicking Continue.
    • The extender is now successfully connected to your existing wifi network.
    netgear ex6200                  Image result for netgear ex6200
