explorer12
Apr 04, 2017Initiate
Change to different wifi source
I want to set up my Netgear EX6200 with a different wifi source. I am using it on a boat and move around quite a bit. I wish to be able to use different wifi in various marinas. I tried to do a fa...
- Apr 07, 2017
Hello explorer12
You have to factory reset the unit for every new router you want to connect the unit to make sure you hold the reset button for 10 + seconds.
DarrenM
explorer12
Apr 07, 2017Initiate
When I follow the instsructions, puch in the reset pin in the back and hold for seven seconds, it does not seem to do a true factory reset. When I sign in to the repeater, the old named 2.4 and 5 mhz networks are still showing. By all rights with a factory reset, they should not be present any longer.
Any tips to assure a complete factory reset?
TheEther
Apr 08, 2017Guru
Log into the EX6200, go to Settings > Other and select the Reset option.
- steventurnerApr 10, 2017Aspirant
Is the same for an N300?
TheEther wrote:Log into the EX6200, go to Settings > Other and select the Reset option.
