explorer12's avatar
explorer12
Initiate
Apr 04, 2017
Change to different wifi source
I want to set up my Netgear EX6200 with a different wifi source.  I am using it on a boat and move around quite a bit.  I wish to be able to use different wifi in various marinas.  I tried to do a fa...
  • DarrenM's avatar
    Apr 07, 2017
    Hello explorer12
    You have to factory reset the unit  for every new router you want to connect the unit to make sure you hold the reset button for 10 + seconds.
    DarrenM
