RSquirrel
Jul 03, 2014Aspirant
Change WEP>WPA on Extender Only?
Now that I have my WN2500RP successfully extending my primary WiFi (unfortunately only with WEP encryption - it's the only option from condo-supplied Wifi), I would hope to improve my security by chan...
jmizoguchi
Jul 03, 2014Virtuoso
WPA-PSK is still consider hackable unless you use WPA2
Just 2cents
Between WEP and WPA , both are easy to be hacked .
Just 2cents
