RonMele's avatar
RonMele
Follower
Mar 24, 2016
Client Signal Dropping
My range extender keeps dropping the client signal.  The router link LED is steady green and when the client signal is broadcasting it is also steady green.  The problem is that the client signal reguarly drops off...and the LED shows it by being off.  Any suggestions are most appreciated.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello RonMele
    I would make sure you are on the latest firmware also try changing the wireless channel to get a better signal and less interference.
    DarrenM
