Admiraal's avatar
Admiraal
Follower
Oct 11, 2012
Connect WN2500RP to Linksys WRT54G
Hello,
I recently bought an extender Netgear WN2500RP which I want to work together with a wireless Linksys router WRT54G, but without success.
Is there any known problem with compatibility of these two items?
I cannot let the extender connect to my existing network on the Linksys router.
Any help is appreciated.
Albert
  • Please check if "Short Preamble" option is enabled in WRT54G.
    If yes, disable it and try if WN2500RP is able to connect.
  • Check if "Short Preamble" option is enabled in WRT54G. If yes, try disable it and try again.
