mbrandt
Jul 26, 2017Follower
Connected, no internet WN3000RP
I have updated firmware and done a factory reset multiple times. I am still getting the "Connected, no Internet". I have restarted my routers and the extender. I have checked and it IS using the s...
- Jul 28, 2017
If you think something is wrong with the unit you will have to contact support if it is still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
DarrenM
Jul 28, 2017Sr. NETGEAR Moderator
DarrenM
