No internet
6 TopicsConnected, no internet WN3000RP
I have updated firmware and done a factory reset multiple times. I am still getting the "Connected, no Internet". I have restarted my routers and the extender. I have checked and it IS using the same IP Subnet. I am out of options and wondering if this is damaged somehow by recent weather and power outages.Solved4.7KViews0likes1CommentNetgear N300 WiFi Range Extender
I have a range extender (Netgear wn3000rpv3) that has been working fine for a couple of years. Yesterday, it gets unplugged due to cleaning. Upon plugging it back in, the network pops up just as before without any messages saying there is no internet access, but all attempts at going online hang indefinitely. This is across multiple devices. I tried turning it off, unplugging it, etc. to no avail. I even did the factory reset, and set it up on the previous network just as before, and it has the exact same hanging issue! One thing I have noticed is that since yesterday (and before and after the reset) the top right led (devices?) generally glows red although it sometimes switches to green for a brief time. Any help is appreciated, but please don't tell me to update the firmware unless this is a known past issue fixed in a release, because it was working fine yesterday. Thanks2.6KViews0likes1CommentConnected to Extender, but no Internet
Hi All I just purchased a Wifi Extender due to poor signal for my Android Box in another room as well as to help increase the signal strength across the house. I want to use the ethernet plug from the extender directly to the android box as I've heard that's better than the wifi path. The issue I'm having is that I can get my devices to recognize the extender, and connect to it... however they are not able to connect to the internet. I've tried multiple factory resets, both with setup via ethernet cable/WPS and still am not having any luck. I am able to connect to 192.168.1.250 when I have the EXT network selected, however no other pages will load. The Extender I have is N300 / Model EX2700 The router I have is Linksys EA4500 Any help will be appriciated! This is driving me slowly insane :)Solved427KViews0likes17CommentsHad the AC750 for a week and have already needed to restart router to maintain connection?
I bought this extender less than a week ago and at first it worked great. Then today suddenly my phone and computer could not access the internet. They both had full bars from the extender, and could connect to the extender, but could not access the internet. They could both access the internet directly from the router when I moved close enough, however, so I know the problem is with the extender. I unplugged the extender, then unplugged and replugged in the router and waited for it to boot up, then replugged in the extender, and everything worked fine. Unfortunatley the router is in my landlords house so I had to ask to enter his house and do this. I don't want to have to do this every five days. Please tell me: is there something else I can do to prevent this from happening again?3.8KViews0likes1CommentHelp! WN3000RP range extender no longer connects since Windows 10
Hi All, I have found other posts on this community and the Microsoft community with users struggling to understand why their extenders no longer work. I took advantage of the free Win 10 upgrade but now am very frustrated that I can no longer connect to the my range extender. I have already: ensured the latest firmware is installed, shut off anti-virus protection and completed reboots of both my Netgear wireless router and extender. I'm out of options. Others must fill this pain. It makes no sense to me that this device (Lenovo Laptop) can connect to the wireless router but not the extender with the exact same info. I've completed all the obvious trouble shooting and different combinations of logging on. I am eager to hear another idea of how to solve this without giving up and buying a new extender. Sincerely, Jonathan3.3KViews0likes4CommentsEX6100 wifi extender set up troubles
Hi I've been trying to install the range extender without much success. the genie didn't start up, so connected directly and went in through 192.168.1.1. Had trouble with passwords, but thought I worked it out, There was no check box allowing me to use the same security settings.Can I have a different password on the extender from the router? Still couldn't access any wireless devices properly. had all green lights, but no internet and each item required a login and password - would it be admin/password? What happens if I don't connect them all before clicking continue (page 11 of set up guide) Can they be connected later? This morning tried again, still no internet access, and couldn't get an windows device to connect to the network at all through the extender. Went through the factory reset then updated firmware bypassing genie. Now it wants me to sign in but won't accept admin/password. What do I do now? (I'm tempted to throw it away, but a waste of money). All I wanted was something to plug in which would make the existing wireless network stronger at the other end of the house.3.9KViews0likes1Comment
