mbrandt
Jul 26, 2017Follower
Connected, no internet WN3000RP
I have updated firmware and done a factory reset multiple times. I am still getting the "Connected, no Internet". I have restarted my routers and the extender. I have checked and it IS using the same IP Subnet. I am out of options and wondering if this is damaged somehow by recent weather and power outages.
If you think something is wrong with the unit you will have to contact support if it is still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
1 Reply
- DarrenMSr. NETGEAR Moderator
DarrenM
