anupambanerji
Feb 13, 2018Aspirant
Connecting AC1200 EX6150-100NAS Range Extender to Ring Video Doorbell
I connected my AC1200 range extender to my FiOS router yesterday and my iPhone and Mac had no trouble connecting to the 2.4GHz and 5GHz bands on the range extender. When I tried to connect my Ring Doorbell, however, it only detected the 2.4GHz band, and couldn't connect to the range extender. It connected to my FiOS router just fine, but the range means that the doorbell has a poor connection.
This is why I purchased the range extender in the first place. Has someone managed to successfully do this before? I'd hate to return the range extender, but I may need to.
Thanks.
Thanks for your reply, Dexter.
After spending 30 minutes with the Ring support team, they fixed the issue by factory resetting the video doorbell and the product re-connected to the extender without issue. It works just fine, and I don't get connection droputs at all.
The trick is to switch over from the router to the range extender by resetting the Ring device, which isn't explicity metnioned in the instructions, and I'm happy to say the Range Extender works without issue.
- DexterJBNETGEAR Moderator
Hi anupambanerji,
1. What is the firmware version of the extender?
2. Checking on the Ring Doorbell specs linked below, it looks like it is a single band device and can only connect to the 2.4GHz.
https://shop.ring.com/products/video-doorbell
3. Please make sure that the credentials (i.e. WiFi password is correct during setup procedure) are correct.
4. Have you tried changing the wireless channel for the 2.4GHz band on your main router?
Dexter
Community Team
Hi anupambanerji,
Thank you for the update and confirmation. Glad to know you got it working.
Dexter
Community Team - anupambanerjiAspirant
