rray6
Jul 24, 2020Initiate
Connecting an EX7300 Extender to a Nighthawk AX8 RAX80 Router
I have an EX7300 Range Extender and a Nighthawk AX8 AX6000 WiFi 6 Router (RAX80). I need expanded coverage for the dead spots in my house and ethernet access points are not a good option for me. I ...
- Jul 24, 2020
They both have it if their on the current firmware. V1 of the EX7300 got the mesh feature in firmware 1.0.2.136
Which version is on the EX7300?
You can log into it and setup the single ssid function through the browser. you might have to rerun the setup.
you can find the manual and firmware here. https://www.netgear.com/support/product/EX7300.aspx
Just make sure you select the correct version as there's 2.
Jul 24, 2020Guru - Experienced User
