lotsokids
Aug 13, 2014Aspirant
Connecting extender to hotel login page
I have a guest network that requires a web page to open and a password to enter network to use (like hotel login), but I cannot get extender to allow me to enter a webpage and login so it says it cann...
RWHeadlee
Nov 17, 2015Aspirant
I too am having this problem. Has anyone found an answer to this issue?
- nhannNov 17, 2015NETGEAR Employee Retired
Hi RWHeadlee,
Can you please clarify what device you are using? and your issue?
If you can answer any of the above questions from other users, that would be helpful in determining your issue.Thank you
- RWHeadleeNov 17, 2015Aspirant
I am using the WNCE3001 on a computer that does not have a wireless card. I have been able to connect the WNCE3001 to my home network with n o problems. The computer is Microsoft XP.
Hi RWHeadlee,
Are you able to follow the "Installation without WPS" listed here?:
http://www.downloads.netgear.com/files/GDC/WNCE3001/WNCE3001_IG_20SEPT2011.pdf
You will need to factory reset the WNCE3001 if you are trying to connect to the Hotel network
Use a pin or paperclip to press the Reset button and hold it for 5 seconds until the power LED blinks amber.
