ciaravella
Sep 06, 2017Aspirant
Connecting Netgear AC1900 WiFi Range Extender as Access Point to HomeHub4
Hi All,
Hopefully someone can help.
I have a HomeHub4 and two Netgear AC1900 WiFi Range Extenders (EX7000).
I have a SONOS system and previously (With Virgin Media), the EX7000 was connected to the Hub and then the SONOS was connected to this EX7000. The reason I did this was to keep the SONOS separate to the Virgin network so that the children could connect to the Virgin Hub but not control the music on the SONOS system as they were on different networks.
I am trying to get this set up again but am currently failing, any help would be appreciated.
So far I have:
- Connected the HomeHub4 to broadband via BT socket.
- Connected the Ex7000 to the HomeHub4 via an ethernet cable
- Connect to the Netgear EX7000 and then goto www.mywifiext.com at which point it doesnt connect, however on the Netgear it shows a ethernet connection with the green light, when signing into HomeHub4 it shows a connection on the LAN port by no further details.
So my question is how can I set up the Netgear EX7000 as an access point with a different subnet.
Many thanks
- DarrenMSr. NETGEAR Moderator
Hello ciaravella
On your main router find the connected devices and then find the IP address of the ex7000 use that in your web browser and it should bring up the settings of the ex7000.
DarrenM
- ciaravellaAspirant
I have the IP address of the EX700 but I want it on a different subnet so that connecting to the BT hub won't allow access to the EX700 network but I can't connect to the ex700 if I change the subnet
