hughbacca's avatar
hughbacca
Novice
Jul 24, 2014
Connection to network but not internet on one device
Hi,
I recently got a WN3000RP. I found the set up easy and was able to connect all my devices (pc, laptop, phone). I set up the extender on my pc as this was the main reason I bought it due to a weak wireless card.
It worked fine until I turned off my pc, when I turned it back on it connects to the SSID_EXT but does not connect to the internet. All other devices I have tried are able to connect to the internet just fine through the SSID_EXT network.
I moved my pc into range of the router and it also can connect to the internet fine through that network. Can anyone help me on this???
  • michaelkenward wrote:
    Can the PC connect to the WN3000RP by LAN?
    Yes it connects to the LAN but not to the internet. All other devices I have connect to both.
  • If you just want to connect wired on your pc I suggest you disable the wireless card.
    Please check if the local adapter is set to dynamic or static.
    Is it a valid IP address within the router's range?
    Also check if the DNS address.
    If DNS not pingable try to set a static DNS on the extender using the router's IP address.
  • Hello,
    I have the same problem, I can connect to the WN3000RP but i haven't got internet.
    What can i do?
    Thanks
  • Hi iNTXIXU and Irms,
    Please get the Status page of the WN3000RP for further investigation.
