Fir3's avatar
Fir3
Connectivity Issues with EX7000
I keep running into issues with my EX7000 when connected via Lan.
Whenever i boot up my PC (Win10) I seem to not be connected to the Internet. Logging into the Extender shows both 2.4 and 5 GHz
connected to the router. Giving the Extender a quick reboot resolves this, but is just tedious for such a pricy product.
I set it up just like the manual had me do, in the next room where the router is and over WPS (also tried it with the Smart Setup but i keep running into the same dilemma).
Everything is running on the current Firmware V1.0.1.90_1.0.156
Cheers for any help and stay safe
  • plemans's avatar
    what router are you connected to?
    Have you tried setting the extender with a static IP address from your router?
    You've tried installing it using the installation assistant? (instead of wps)
    • antinode's avatar
      antinode
      Guru
      > router?
         Terminology: A "static" address is configured on the device itself.
      What you configure on a (DHCP server on a) router is a reserved dynamic
      address, not a static address.
         If it's "from your router", then it's a reserved dynamic address, not
      a "static" address.
    • Fir3's avatar
      Fir3
      Yes I did try using the installation assistant as well, but sadly end up with the same result.
      When it comes to setting a static IP i gotta be honest that i dont really know much about managing my own network so I ll try to read into that when i have the time.
      As for the router, its just a generic base router I got from the ISP here in Germany, no aftermarket product.
