Lala2323's avatar
Lala2323
Daisy Chaining
Looking for knowledge before I attempt the install. Looking to boost our wifi purchased two routers:
  • NETGEAR Nighthawk X6S AC3600 Tri-Band Wi-Fi Router
  • NETGEAR - Nighthawk X4S Dual-Band AC2600 Router with 32 x 8 DOCSIS
I want to daisy chain them together to get long range wifi and do no know the first step...
  • Will this actually be a good set for fiber in a 3100 sqft home? I have the ability to take the 2600 back and get two 3600...
  • If I keep the current set up, should I use the AC3600 as the base and have AC2600 as the extender?
  • Is there a step by step doc or tutorial on how to accomplish this goal?
Thank you for help ahead of time!
