grubbii
Jun 22, 2012Follower
Devices Won't connect to extended 2.4Ghz
I bought this device and hooked it up today...got the latest firmware and have been testing since. I have a dual-band Cisco E3000 in the basement of a 3000 sq ft home. On the first floor, I put the ...
JBID
Dec 04, 2013Aspirant
My solution was different than that link. For WEP, when you are using the Wizard to set up your account, and you get to the screen (2nd, I think) where you enter your WEP..DO NOT ENTER IT IN THE GIANT SPACE CALLED PASSPHRASE with the button Generate next to it. Nope, you should ignore that giant huge obvious spot and just type it directly into Key 1 ONLY. Also ignore all the other KEY fields.
I had to go back to factory settings to be able to do this, but that's all it took (I won't tell you how long it took me to figure out that.) Seems like there should be some instructions on that page...
