Karaptian's avatar
Karaptian
Disable 2.4 Ghz network
I have a Nighthawk MR60 system.
I would like to disable the 2.4 Ghz network.
I followed the following steps, but was unable to locate where I can disable the 2.4 GHz network.
Log in to the router using the router's web interface:
Open a web browser on a device connected to the router's network
Go to www.routerlogin.net
Enter the router's username and password
Select the Advanced tab
Select Advanced Setup
Select Wireless Settings
