Kort2127
Sep 14, 2018Aspirant
Does ex6120 work to extend google fiber?
I have been searching a bunch of sites for info and some say yes, and others no. Please advise before I waste more time trying to configure. I'm not the best with this stuff and quite frankly, I'm ...
Sep 14, 2018Guru - Experienced User
It should be able to extend any reasonably modern wifi network.
What are you using for your router?
- Kort2127Sep 14, 2018Aspirant
It's the google fiber router and doesn't support WPS
- StephenBSep 14, 2018Guru - Experienced User
You don't need to use WPS to set up the extender. So that is not an issue.
Do you know if it is the GFRG110 or the GFRG100?
Neither. It's GFRG210 .
Thanks again for your assistance.
