Kort2127
Sep 14, 2018Aspirant
Does ex6120 work to extend google fiber?
I have been searching a bunch of sites for info and some say yes, and others no. Please advise before I waste more time trying to configure. I'm not the best with this stuff and quite frankly, I'm ...
Kort2127
It's the google fiber router and doesn't support WPS
Sep 14, 2018Guru - Experienced User
You don't need to use WPS to set up the extender. So that is not an issue.
Do you know if it is the GFRG110 or the GFRG100?
- Kort2127Sep 14, 2018Aspirant
Neither. It's GFRG210 .
Thanks again for your assistance.
- StephenBSep 14, 2018Guru - Experienced User
There's not a lot out there on the router specs, but it looks like it delivers AC1700 wifi network - dual band with 3x3 802.11ac at 5G.
The ex6120 should work ok.
Thanks. So now I just have to figure out how to set it up. Just gave it a stab from a youtube video but it doesn't appear to be working.
