kasaattila
Mar 05, 2016Aspirant
EAP-MSCHAP v2 - Netgear WN3100RP
Dear Community,
I need to know is it possible somehow to set up a known network with the known USERNAME and known Password on the Netgear WN3100RP?
I would boost up the located WiFree signal, but I didn't find any option to give my UserName & Password, it would get only a password, but it is not enough for the connection!
I've got the latest firmware installed on the extender/repeater, but I doesn't find that option :( Maybe somebody could tell some trick or hints...
Thanks in advance!
Attila
- Thanks for your help a lot!
Looks like you need an extender that supports WPA2 Enterprise. According to the data sheet (link), the WN3100RP only supports WPA2-PSK. I don't think any of Netgear's extenders support WPA2 Enterprise.
You may have to use a router that supports DD-WRT (3rd party firmware) to do what you want. I found a thread on dd-wrt.com that talks about how to set it up (link).
- kasaattilaAspirantThanks for your help a lot!
