tafkaltlg's avatar
Sep 17, 2022
EAX20 extender networks setup but no internet
New Netgear Nighthawk EAX20 extender, ran setup with wizard, installed fine.  Extender found and connected to Motorola MT8733 no problem.
Devices connect to extended networks ok, but no internet.
Devices connect to original network of motorola just fine with internet
Saw another thread suggesting problem with security settings of the modem/router (not the extender)???
Anybody have any workarounds?
1st pic = shows networks >
2nd pic shows TCP/IP of regular network (Jack's) -  motorola modem/router ip is 192.168.0.1
3rd pic shows TCP/IP of Nighthawk extended network- netgear extended router ip in 192.168.1.250
Will the nighthawk just not play nice with a motorola modem/router?
  • plemans's avatar
    What happens when you factory reset and run setup using the WPS push button method?
    (it'll have the same ssid as the router so won't show up separate as WPS installs in mesh mode)
    • tafkaltlg's avatar
      tafkaltlg
      Tutor
      Factory re-set,
      setup using WPS,  both 2.4 and 5g networks and guest networks appear, broadcast and can be connected to-  but still no internet
      • plemans's avatar
        I don't believe you reran setup or it didn't reset properly. (not saying you didn't do it, just something wasn't done right) Reason I say that is the default option when you setup using WPS is the "one wifi" option where it has the same ssid as your router that you're connecting to. Yours is setting up with the _EXT extension. Which isn't default.
        What router are you connecting to?
        What modem/gateway is the router connected to?
        did you go in and set a static ip address?
