jvogal70
Feb 22, 2020Aspirant
EAX80 - 5ghz weak signal when using 5ghz 160HT mode on RAX120 router
I have an RAX120 router and just received an EAX80 range extender. Upon setup I noticed that when I have AX Enabled w/2.4 & 5 ghz OFDMA enable + the 5ghz mode (up to 4803 Mpbs (11ax, HT160, 1024QAM)selected on the router, My 5ghz signal on the range extender drops to 1 bar signal strength (red) with ~108Mbps, but still an availabe wireless mode of upto 4800Mpbs. If i change the router 5ghz mode to (up to 4803Mpbs (11ax, HT80, 1024QAM) then the signal strenght returns to all bars (strong/green) with ~1441Mpbs, however the wireless modes drop to 2400mpbs. This happens wherever I place the Range Extender. I put it in the same room as the router ~2ft away and the same thing happens,
Is there anything that can be done to resolve this issue. I bought the range extender for HT160 support, but it appears i am not getting what i payed for....
On a side note, if I disable AX it appears to work with HT160 (good signal, showing 4800 wireless mode, however, my wireless speeds drop to about ~30-50Mpbs from ~300-600Mpbs
1gb download(~945Mbps) / 45Mbps upload - comcast Internet using a CM1150V modem
Smart Connect and 1 WiFi name is also enabled
- jvogal70Aspirant
Now it is dropping WiFi signals all together and some devices are not even able to connect. I am returning it and going back to using my EX8000 Range Extender. This RE is a piece of garbage.
- I've had this issue since November 2019. They sent me a replacement back in November after spending an hour with support. Doesnt matter if its 2ft away, it will just drop connections. Getting a replacement will not fix the issue, it's a problem with all EAX80's.
I have an rax120 too, so it could be an issue when paired with the rax120. Little disappointed they havent had a firmware update to fix this issue that has been reported doe months.Does anyone know if Netgear plans on fixing this issue? I'm so confused on how their site is showing good reviews for this product when it clearly doens't work. I've gone through 2 of them, and have had the same issue.
- dcincaApprentice
If i turn on HT160 on Rax120, the speed test on my Eax80 is only like 30ish Mbps(500+ Mbps in HT80 mode).... Fix HT160 function please!!!!
