mdaubs
Jun 13, 2016Aspirant
Error creating account on EX6200 Wifi Extender
My EX6200 wasn't working properly, so I had to restore it to factory settings. After running the setup wizard, I was taken to a screen with a "New Extender Setup" button. Once I click that, I'm taken...
Danny123
Jun 14, 2016Aspirant
I have the same problem..
Can someone help please?
DarrenM
Jun 15, 2016Sr. NETGEAR Moderator
I would try to clear the browser settings and then try to use www.mywifiext.net to login to the extender.
DarrenM
- mdaubsJun 15, 2016Aspirant
Thanks for the suggestion, but the error persists. If it helps, I've tried this from multiple computers/devices and multiple browsers (Firefox, IE, Safari, Chrome) and the result is the same every time. The issue seems to be that the code to build the login page is, for some reason, showing up in the URL. Because of that, it appears to be an issue with the updated firmware rather than user error. Unfortunately, since I can't access the extender's settings anymore, I can't downgrade to an earlier firmware to test this.
- DarrenMJun 15, 2016Sr. NETGEAR Moderator
mdaubs
You could try to downgrade the firmware using TFTP here is a article on how to do it for routers so I am not sure if it will work for a extender or not.
http://kb.netgear.com/app/answers/detail/a_id/22688
DarrenM
- WhiteApacheJul 03, 2016Aspirant
I have the same problem... (With the last version of firmware...)
Some news about this....
Thanks !!
PS : The solution from DarrenM don't work for me...
