fsamuel
Oct 15, 2016Aspirant
Ethernet cable out not working
I just bought a EX3700. The only reason is because i have an interactive TV box that only takes ethernet cords for some reason. My router is in the other room so i don't want a really long cable goin...
fsamuel
Oct 18, 2016Aspirant
yes, i have done that and i do believe that it does show up. But the problem is that there doesn't seem to be a actual internet connection between them. The interactive box does not work. but when i plug it back into my modem and reset... it does work.
DarrenM
Oct 20, 2016Sr. NETGEAR Moderator
Hello fsamuel
Is there any type of internet settings you can get to in the box where you can see a Ip address maybe if you set a static 192.168.1.x address it will connect.
DarrenM
