platipus's avatar
platipus
Ethernet Port Speed
Not sure if V3 is the right version or not. The box it came in says WN3000RP-100NAS
I have a small piece of electronics that seems to need a hard coded 10mb Full Duplex ethernet port. I have the N300 configured as an Extender and attached to my existing WiFi. If I plug a regular PC into the ethernet port, it works.
If I plug this device I need to use directly into my switch and config my switch port for 10mb/Full, I am able to connect to it. If my switch port is set for Auto/Auto, it will not negotiate/connect to this device I need to connect.
So what I would like to do is hard configure the ethernet port on the N300 for 10MB/Full. I don't see anywhere that this is possible to do though in the web interface and there appears to be no CLI available.
Thanks!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello platipus
    Yea I do not see a option for this.
    DarrenM
    • platipus's avatar
      platipus
      Thanks for the response! Guess it's been made too "user proof"....
