mstith's avatar
mstith
Tutor
Aug 21, 2022
EX 3700 extender 2 g band no longer working
My 2 Ghz band no longer works (connected no internet) I have tried to factory reset through the setup; AND STILL NOTHING -  NOT sure what to do besides trash it an buy some other extender.
Thanks,
  • plemans's avatar
    What firmware is on it?
    What router are you connecting it to?
    did you set it up using the wps push button method of setup?
    • mstith's avatar
      mstith
      Tutor
      Firmware:  V1.0.0.96_1.0.62  Recently updated
      It is an xfinity router-
      I have set it up using the online setup (genie).  I haven't used the WPS method ever.
      Thank you!
      • plemans's avatar
        What xfinity router is it?
        Are you using any special characters or spaces in the ssid/password? If so, try removing them.
        You can also try using WPS. I'm a fan of the installation assistant but sometimes wps works well
