Natey2's avatar
Natey2
EX2700 and connecting to mywifiext.net
I can't connect to mywifiext.net
I can connect from my Android phone to the EX2700's WiFi network, but when I hit that site, I see:
{ "reset":"1" }
So I went into my primary router, found out the IP Address this EX2700 was using, and connected to it directly:
http://192.168.1.127 (in my case)
And it worked.
Is www.mywifiext.net supposed to somehow connect to that IP address??
  • yea but sometimes when the router assigns the extender a new Ip that link fails and you will have to use the direct Ip address to connect.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
