titus46
Mar 05, 2017Tutor
EX2700 unable to connect on Castlenet CBV734
Hi, I tried to connect my EX2700 on Cable router CBV734... Not possible !! With wep security, wpa-psk tkip, wpa2-psk aes or without security give same result : never Led router connexion become gree...
- Mar 12, 2017Bonjour tout le monde,Le problème n'a tjrs pas de solution (ou réponse) pour l'instant.Je ne sais pas pourquoi le CBV734EW n'accepte pas la connexionalors que WGR614 ne pose aucun pb.
DarrenM
Mar 07, 2017Sr. NETGEAR Moderator
Hello Titus46
Did you try to change the wireless channel of that router?
DarrenM
titus46
Mar 08, 2017Tutor
Hi DarrenM
Yes I do. I tried channels 1, 4, 6, 11... no change
- titus46Mar 12, 2017TutorBonjour tout le monde,Le problème n'a tjrs pas de solution (ou réponse) pour l'instant.Je ne sais pas pourquoi le CBV734EW n'accepte pas la connexionalors que WGR614 ne pose aucun pb.
- unnidnairJul 23, 2017Aspirant
How can this be a possible solution - atleast translate to english... As per google translate, this is what it means. Very funny solution!!!
Hello everybody, The problem does not have a solution (or answer) for the moment. I do not know why the CBV734EW does not accept the connection Whereas WGR614 does not pose any bp.
