marc_e
May 24, 2023Initiate
EX3110 AC750
I installed my extender and have no issues connecting to its SSID on either band. However, after installing it, I can no longer connect to my original wifi SSID from any device.
Any ideas what might be causing this?
What router is it?
did you setup the extender using wps or using the installation assistant?
- marc_eInitiate
wps
Factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
