spitlist's avatar
spitlist
EX3700 Access Point Mode is SLOW
I installed the extender in the Access point mode and it is working, but when I ran a speed test, I found that the download speed is less than 10 mbps while the WIFI speed directly to the router is 220 mbps.  What is is that accounts for this drastic degradation in speed?
  • plemans's avatar
    Are you testing the 2.4ghz or the 5ghz?
    Are you sure its setup in access point mode?
    • spitlist's avatar
      spitlist
      I have tested it in both modes and get the same speed (les than 10 mbps).  I set it up in Access Point Mode with the help of a tech support person, so I am quite sure it is set up correctly.
      • plemans's avatar
        I'm never trusting of others because I don't know what they did/setup.
        You could try factory resetting the extender and redoing setup. Maybe something was done wrong or maybe it was setup in fastlane improperly.
