techmom5
Sep 17, 2018Follower
EX3700 set-up issues
Hi there,
I have two netgear extenders one AC1200 and the other AC750. Im trying to set up the AC750 but when I go to the link to set it up I get a message that says "You are not connected to y...
DexterJB
Sep 17, 2018NETGEAR Moderator
Hi techmom5,
Welcome to the community!
It should not be an issue. Just make sure that you connect the device that you are using for the setup to the AC750 first before proceeding. Once connected, you should be able to go through the installation process as described here.
Dexter
Community Team
