soundcrossing
Nov 02, 2016Follower
EX3800 Unable to Connect a Device to 5G
- Hardware Version: EX3800
- Firmware Version: V1.0.0.58_1.0.38
Went through WPS setup and manual setup. Haven't gone through setup while hardwired. 2.4g works fine. 5g shows connected between Router and EX3800 but I cannot connect a 5g capable device to the EX3800. I have great signal between the router and extender and the extender and the end user devices. Has anybody run into this problem and have a solution?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello soundcrossing
I would try to factory reset and do the setup again you may want to try the wired setup.DarrenM
